Old 02-10-2014   #1
Steel weld fitting for oil pan. SS or mild?
Looking to order a weld fitting for my oil pan, but I'm not sure if I should do SS or mild.
I'm thinking SS for longevity, but I don't know if this will cause issues trying to weld it to the pan, so I figured that I would ask.
Thanks
Old 02-10-2014   #2
Re: Steel weld fitting for oil pan. SS or mild?
The pan is steel... why wouldn't you get a steel fitting?
Old 02-10-2014   #3
Can do either. What fitting? Oil return?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 02-10-2014   #4
yes it would be for an oil return.
I know steel would work, but I wasn't sure if SS or mild would make a different in the welding process or if one would be better than the other.
I'm trying to make it all -12AN sized return.
I'm in the process in finding out if they make a T3/T4 oil drain flange to 3/4" NPT, they only seem to make it in T6 or holset.
Old 02-10-2014   #5
Technically yes, would change how you would weld it, but in reality, doesn't matter that much in this application. Either will stick. SS fitting threads will play nicer over time.
GSX - 571whp/490wtq
Sienna
Old 02-10-2014   #6
dsmreck
dsmreck's Avatar
Drives: 98 gsx
it's getting tig welded regardless it will be a matter of filler rod really.
Old 02-10-2014   #7
Correct
GSX - 571whp/490wtq
Sienna
Old 02-10-2014   #8
That's what I thought, but then again not 100%.
I'm a welding nooblet.
Thanks guys.
Old 02-10-2014   #9
dsmreck
dsmreck's Avatar
Drives: 98 gsx
http://www.siliconeintakes.com
this place has all kinds of great fittings etc.
Old 02-10-2014   #10
thanks.
Old 02-11-2014   #11
Might have one laying around. I always use early a weld on fittings. But that is what I got at NWA for all my fittings and lines.
Old 02-11-2014   #12
dsmreck
dsmreck's Avatar
Drives: 98 gsx
why no text back mark?
Old 02-11-2014   #13
I'm not looking to pay retail for a used part.I'm gonna order tonight
Old 02-11-2014   #14
I'm having a custom T3/T4 oil drain flange made that has a 3/4" NPT fitting on it.
