Old 04-22-2014   #1
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Timing belt instalation help
So i know this sounds really stupid but since i have my motor out i am going to do the head gasket and timing belt the only problem is i have never delt with a timing belt and dont want to screw anything up on my motor so if anyone would be interested in helping me out and showing me how to do one that would be awsome sometime this week if possible i will be going to map to pick up a couple things so just let me know thanks guys
Tyler
2011 Subaru Sti 11.0 @135mph
Old 04-22-2014   #2
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: Timing belt instalation help
As far as information about the timing goes:
http://www.vfaq.com/mods/timingbelt-2G.html
I suggest to get the special tools. This is the kit I got.
http://www.jayracing.com/timing-belt...kit-p-214.html
I think you could suffice with the tensioner tool alone. I'm sure there are plenty of people on here with one that would let you borrow it.
Hope this helps.
Old 04-28-2014   #3
longemoco
Timing belt is very easy if you follow the VFAQ. Step #27 I believe tells you to use factory belts. Its very important to use factory. I know from experience.
longemoco is offline   Reply With Quote
Old 04-28-2014   #4
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Super easy, once you do it you'll be astounded. Just make sure the gap is right. I made my own tool using a long grade 10 bolt and re-cutting threads into it, add some lube to threads before inserting works great.
BW8776, e-85
Old 04-28-2014   #5
A little hint, the factory battery hold down bolt for 1G's can be used at the tensioner tool buy threading it up a bit more.
Old 04-28-2014   #6
dsmreck
dsmreck's Avatar
Drives: 98 gsx
I don't even use the bolt anymore. I just use the pin.
Old 04-28-2014   #7
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
I could always help out ive done tons of t belts/ headgaskets
Old 05-15-2014   #8
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Any help would be appreciated for sure thanks for the info also guys
Tyler
