Old 05-04-2014   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Stock Flywheel vs Aftermarket
Alright guys so i'm just curious as to how many of you are using the STOCK awd flywheel? I ordered everything for my trans rebuild and have been debating getting a aftermarket one (ACT, ext..) because i've heard of bad things happening on the stock flywheel. I won't be making crazy power this year, goal is 400-450 by end of summer or what I can get with this 20g.
Any thoughts are welcome
Mark
BW8776, e-85
Old 05-04-2014   #2
Re: Stock Flywheel vs Aftermarket
Lighter flywheels are nice for quick revs, but it doesn't drive as nice. You have to rev it up a bit more to get it off the line. I want back to stock on mine years ago. Just make sure you inspect it for hairline cracks because some have exploded in high horse applications.
Old 05-04-2014   #3
dogwhistle
dogwhistle's Avatar
http://www.dsmtuners.com/forums/driv...-explodes.html
Mark, I have the ACT aftermarket wheel and I love it. It drives just as nice as a stock flywheel and mine is even barely turned/polished for perfection before I put it in. You can even try mine if you'd like. I wouldn't go aluminum unless you knew you weren't going to daily and I would go twin clutch if you have no budget. Long story short, I'd move up from stock if I'm going to the effort of replacing one in the first place.
-Adam
aneujahr@maperformance.com
Old 05-05-2014   #4
mark4g63t
mark4g63t's Avatar
Yea thats the forum I had in mind. I have a act streetlite in my car right now (fwd). Really want the safety comfort one brings but it would push my install date back some.
BW8776, e-85
Old 05-05-2014   #5
I always ran the stock one for drivability reasons.
Old 05-05-2014   #6
mark4g63t
mark4g63t's Avatar
Yes I probably will be running the stock one. My power goals are my only concern.
BW8776, e-85
Old 05-05-2014   #7
I wouldnt be concerned at those power levels, unless its in shit condition or something. I ran 541hp @ DB (628 @ MAP) with my stock one.
Old 05-05-2014   #8
mark4g63t
mark4g63t's Avatar
Sounds good, thats the plan then.
Thanks!
BW8776, e-85
