Old 06-19-2014   #221
Re: Potential Buy 1997 GSX
120 for what the water pipe and t.stat housing. If so that is a total rip off. I have them posted in my clean up sale for 30.00
$120 is for every part that would be needed to replace the entire system minus radiator
(Heater core , thermostat housing all the pipes etc, and actually looking back at his pm. That also included all the windshield washer items I want to put back on the car... rear wiper, front nozzels , etc)
Old 06-19-2014   #222
Originally Posted by typeRA View Post
what youve pictured is that the turbo water feed system is capped off. why? the holsets don't use water jackets.
this will have no bearing on the problems you're having whatsoever.
We were talking about what could be a reason for my coolant temps being so high.
And I mentioned that water pipe being welded shut at the end. And that's where we are at now in the discussion of how would that even work?
Old 06-19-2014   #223
Still to way much money. He would be ripping you off big time
Old 06-19-2014   #224
Hey Brian, Here is what I do have in black. Would you pick these up or have them shipped?*
Black Dash w/ Black Airbag and Vents $125
Lower Door Trims $30
Center Console $50 (complete)
Windshield Washer Tank $30
Rear Wiper Motor and Blade $30
Thermostat Housing $25
Water Pipe $20
Heater Core $25
I do not have a red 2g front bumper. Which year do you want?*
I do also have doors for $75 each or $50 for bare shells.*
Old 06-19-2014   #225
Hook up the heater core. Turn fans on with link (comes on with key) get a 160 t.stat. Better mix of coolant and some wetter water
Old 06-19-2014   #226
Water Pipe $20
Heater Core $25
Those are the prices he quoted me sorry for double post this phone sucks.
Old 06-19-2014   #227
Just find a u pull it yard.
The last black dash I sold for 50 with the bag. They are not that hard to find as people make it out to be.
Old 06-19-2014   #228
Hook up the heater get a 160 t.stat. Better mix of coolant and some wetter water
So far if everything goes to plan. I should have the money for
-mishimoto thermostat
-mishimoto fan shroud/fans
-mishimoto 1.3 radiator cap
The week after the 4th if my schedule comes out with more overtime here at work ill probably jusy hold off and add the mishimoto xline radiator as wellr and do the purchase all at once.
This car is a replacement for a motorcycle that I drove leas then 4 times a year sold it and basically bought this car for the same price except airfare and gas to get home. If this car sits like the bike its no biggie to me.
Old 06-19-2014   #229
Im officially done with this thread, so scattered, not taking any advice, good luck sir.
Old 06-19-2014   #230
The last blast bef dash I sold for 50 with the bag. They are not that hard to find as people make it out to be.
I agree he just happened to have a lot more stuff I wanted on top of that list (that's 1 of 7 lists I sent him)
So to save time in was just going to head to one placenand get it all.
But am waiting for him to find black panels and door trims and rear seat before I head there
Old 06-19-2014   #231
How so? Im listening to everyone's advice.
-Oil type...check 10w-30
-Coolant system.....check
replace the broken heater core, hook up all coolant lines, fans on via link, water wetter, im upgrading all the parts you listed other then water pump for now. I will do everything just takes time even if the car sits but everything you all have suggested is on the list)
-Oil cooler....check..... will dive into this if the coolant issue persists but id imagine there is something else wrong if its not fixed at that point (motor issues would be my guess)
Dyno tuning - definetely not close to ready for that way to many issues to make it worth the price at the moment
-pull a part... makes sense I just happened to like to one stop shop. If the prices are close enough to other places. Then so be it if not of course ill just keep looking?
-wideband sensor , still working with on this with ecmlink forum, once it'd made official that it needs replacement that will be replaced with everything else from map. For now im doing everything im being asked to do by jery1234 on there.
Have I missed something else?
Old 06-19-2014   #232
And Halon, i just want to say again thank you and thank you to everyone who's chiming in and answering my questions and giving me constructive advice.
I hope you all will continue to chime in even if its only when I finally start making progress on fixing all this stuff.
You all are an extremely valuable resource of knowledge and I am grateful to have that knowledge at my disposal, if im making a blatant mistake on something or have miss understood your advice please tell me.
Old 06-19-2014   #233
dsmreck
dsmreck's Avatar
Drives: 98 gsx
holy balls this thing is still going? wasn't this car done and ready to go? Maybe i'm assuming things here sorry just don't have time to read after seeing halons post.
Old 07-07-2014   #234
Well over the 4th, since I was banned decided to swap out thermostats for stock one as well as 15% coolant, distilled water and water wetter and did an oil change.
To start with found the thermostat in there was basically there for the gasket there no middle section you could see straight through (basically center was removed) I have picts but will load them when I do my build thread.
Only drove the car in town short distances and coolant temps were around 206-216
However first trip to work today and a 22miles trip. By the time I got to work and let it idle temps wete at 226 again. So lools like a radiator is next.
And we'll would say I would order it this week only now the motor in my X5 is out yet again after 29,000 miles. Warranty was for 25,000 go figure as thats just my luck.
Old 07-07-2014   #235
Sounds like the previous owner was aware of the high coolant temp issue if he already gutted the thermostat. Hopefully a new radiator helps...and good luck with your X5.
Old 07-07-2014   #236
Sounds like the previous owner was aware of the high coolant temp issue if he already gutted the thermostat Hopefully a new radiator helps...and good luck with your X5.
Thanks, im pretty sure im just going to unload both my bmws and get a truck for the wife.
Her 740 now has the same vanos timing system check engine light my x5 had when the motor went oit the first time. only this one is pulling a code for both not just one. I cleared the code friday and it came back this morning. Supposedly its a $2200 fix for a car not even worth $3500.
Btw doesnt scale there parts like the rest of the car companies it seems.
Old 07-11-2014   #237
Update - ordered up my first parts from map yesterday.
xline radiator and mishimoto radiator cap.
With it raining a lot lately outside temps have been in the high 80's and in turn my coolant temps have been anywhere from 193-206 cruising all week. But I know its not even the peak of the warm weather yet here. So I went ahead and ordered it up as august usually is the hottest time of the year with regular outside temps over 105+ and I know that is just going to put the car back to where it was with coolant temps.
I also found a guy selling a gForce carbon fiber hook never installed here locally (20miles from my house)
I did a quick search and cheapest if found them for was $600 and I believe it was vibrating listed it as $1000 (did the search a few days ago)i know I was reading a thread a few days ago from dsmwreck where they were looking into hoods for the white 2g.... what would be a good price for that hood?
What he emailed me for asking price is almost borderline to good to pass up kind of situation. I planned to replace my hood this coming tax season as the edge of mine looks like it was dropped or something and is bent. So before I get paint I was going to replace or have to have it fixed.
If it wasn't for his asking price I wouldn't even normally consider it till I got a few more things for my car that normally would taken priority
Old 07-11-2014   #238
http://www.carid.com/1998-mitsubishi...-13005974.html
Here's a link to the hood in question
Old 07-11-2014   #239
http://www.andysautosport.com/mitsub...r01020559.html
Same hood only different company/price.
Old 07-11-2014   #240
Can you just make a build thread already?
