Old 04-10-2015   #41
Re: Over Boosting? Need some help guys
Originally Posted by talonsway View Post
Imma run a 10cm t3 turbine hosing on my 16g. Then get a nice t3 manifold, with a provision for a external wastegate. Then get a flange for the o2 housing and weld an elbow on it and maybe do a v-band down pipe i have always wanted.
Seriously, why not just port the wastegate hole?
Old 04-10-2015   #42
lolz! So complicated.
Old 04-10-2015   #43
Have fun with a 16g that lags like a 62mm with that housing.
Old 04-10-2015   #44
jeremy1375
jeremy1375's Avatar
Troubleshooting guide:
1) Your waste gate is welded shut or stuck closed. The lever on the flapper may be slipping on the pin or whoever welded it used a different piece of metal and let flapper swing freely.
If 1 is not the case goto 2.
2) You didn't really disconnect the flapper. Disconnect it.
If 2 is not the case go back to 1.
Old 04-10-2015   #45
1990GSX
Drives: 1975 corvette stingray, 2008 evo x gsr
I concur... I really don't think you had it open. The gate is designed for the turbo. There's a difference between it creeping up to 30 and just spooling strait to 30. Sure you may have the one oddball wastegate thats wayyyyyy too small but I doubt it.
1990GSX is offline   Reply With Quote
Old 04-10-2015   #46
may be take some pictures of your set up and post them up.
Old 04-10-2015   #47
"I see a T3 / TDO5 turbo Dominic..."
Tags
all the boosts!
