Old 06-18-2015   #901
Re: 91 Galant VR4
Lol at that duty cycle.
Good luck, it's been a long road.
Old 06-18-2015   #902
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: 91 Galant VR4
Bringing fully operational spare transmission in car ha just in case! We will find you guys once we arrive hoping to see some fun roll races if all goes well Sunday 2, against some of those NF subaru's if they actually are bringing that red crazy hatch out lol.
Old 06-24-2016   #903
Re: 91 Galant VR4
Where to start....
So the fuel change was a good thing for the car, off E98 and onto RAT K16. ATM we are at 72-74% duty cycle @42psi and log wise the car is happy. It has not lifted the head, even though its spendy I now have some street miles on the car and built up the confidence I need to get back to the track and try and try to better our 2011 peak of 9.45@156.9.... that seems like a lifetime ago now but we are still after it.
At the end of the 2014 season we hot lapped the car and hurt the trans, and also burnt a hole in the #4 exhaust runner into the coolant passage on the center divider, and we had major clutch slip issues with the Quarter master twin disk, and we broke an ass load of rear axles along the way.
So pulled the head and valve, welded and reinstalled, ordered a Competition Clutch Triple disk and DSS stage 5 rear axels. I forgot about the trans over the year and fixed the head issue, then at PG in 2015 with the Rocket boys holding up the show we figured out the trans was hurt, and we were limited to WG boost pressure, wiring issue to BCS. But the final pass of the day was a 11.8@130 with only 21psi.
Now onto this year... after helping 2 local guys with trans builds I was trying to figure out how I could make this syncro mitsu parts trans work. I am still in the boat of no dog box, even the face plated trans at list price is out of my sights. I also worry I am well beyond what the stock gears can handle and putting a ton of money into faceplating does not make sense.
Also we were are having a hard time to get the car off the line at a sticky track, so the tall EVO 3 1st gear and 26" tall slicks proved to much. We were not able to up the power at the line enough to get the tires to spin in fear of breaking stock driveline parts, we adjusted the rear suspension to limit weight transfer, but with the hurt trans, low boost, and limited track time its hard to say if that will help us.
So over the winter I ended up using a Stock DSM 1st gear, but with reving to 9800rpm the 1/2 split is not ideal but working atm, and with a hole stack of fresh synchros I also shimmed the trans super tight, I found some info on how much more pre load I should be putting in based on HP level.
We also finalized our plans to make this a 4 speed trans to reduce weight of the input shaft and make less work for the synchros. So all said and done we were able to reduce the weight of what needs to change speed on shifts by 17%. Its a little harder to get into reverse but the up shifts have been super smooth, I also installed a trans temp gauge so we can make sure we have enough trans temp and not to much to over work the fluid. This was a easy modification and I was able to eliminate everything to do with 5th gear. So the trans is a little easier to work on now, lol.
I also picked up a dash cam and made a mount for the harness bar and we now have a little bit of good footage from inside the car and I am excited to get some footage at the track with it also.
HP wise IDK where we are at, but at 42PSI the car goes from 60mph-130mph in 4.15 seconds with a passanger. The numbers are looking good and over the next few weeks I will get updated pics and some hard data from the track.
I also raced my buddy Bill in his 69 chevelle with a 800hp BBC and a TH400 trans. He did a 130' long burn out, but pulled to my front bumper, then I shifted into 2nd and drove around him, with a 275lb passanger, this was at 38psi peak bleeding off to 32psi. still working on the ECB stuff, which is better now and around 42psi.
Old 06-24-2016   #904
Re: 91 Galant VR4
Very cool man. Excited to see you get out there again! What turbo setup are you on again?
Old 06-24-2016   #905
Re: 91 Galant VR4
Borg Warner billet 76mm with the 83mm turbine in a 1.00 divided housing with a fully divided header. I will add the full mod list again when I get the pics updated.
Old 06-24-2016   #906
Re: 91 Galant VR4
Should be fun getting it dialed in here at the track shortly
Old 06-24-2016   #907
Re: 91 Galant VR4
Are you running boost by gear then?
Old 06-24-2016   #908
Re: 91 Galant VR4
No VSS yet, but eventually it'll be a progressive boost (boost by MPH).
Old 06-24-2016   #909
Re: 91 Galant VR4
Nice. That should help the 1st to 2nd gear issues too.
Old 06-24-2016   #910
Re: 91 Galant VR4
Nice. I've been starting to eye their new S300-SXE line. SX turbos beefed up with better bearings, and borrowing the badass comp wheels from the EFR line. 69mm rated around 1000hp. I think yours is maybe rated close, or a tad higher maybe?
http://www.full-race.com/store/turbo...9180-69mm.html
Old 06-24-2016   #911
Mark Leasure
Mark Leasure's Avatar
Re: 91 Galant VR4
Awesome, great to have it up and running! And stronger than ever, rear axles will help a ton. Are you thinking of coming on up to BIR for show and go over the 4th? I plan on being there with the talon.
www.maperformance.com
Old 06-30-2016   #912
URV8SUX
URV8SUX's Avatar
Re: 91 Galant VR4
Good at stuff john, lots of hours working on i it in sure. Looking forward to the new updates photos, what storeys the car weigh?
Is the car still on v1?
Is it 4 lug?
Old 09-24-2025   #913
Re: 91 Galant VR4
Good evening, I am John a grateful believer in Jesus in recovery of alcoholism and struggle with lust and worldly things.
I have been MIA for a long while, I still have the car and started to make headway on a few smaller projects and just getting the car out a few times late this year.
I have a mountain of new parts and a rough plan moving forward with the project.
I have some photos I can work on uploading and a few videos.
It was great to see you Nate at the All Mitsu cookout. I was able to give my daughter a ride in the car up to the cookout, Liana is 12yr old.
I have not weighed the car in a while but I think its 2550lbs, I am on the Beta version 2 AEM EMS, It is a 4lug still currently on mickey thompson ET street R 24" tires.
I also picked up a draggy and will try and gather data before winter.
