Old 08-22-2015   #1201
Re: Project Lex
I didn't keep the car long enough to know how long it lasted haha.
But I just texted the new owner, he said it died on him after sitting all winter. I installed a cutoff switch on the battery so it would last longer, but he forgot to do that and killed it. So I guess you just have to be a bit more careful with them compared to a normal battery, if you can get 15lb lawnmower matteries every year for $25, that's probably a better route.
Old 08-24-2015   #1202
Re: Project Lex
Corbeau's ftw. LG's are like the wide fat man seats of the Corbeau lineup too.
Old 08-27-2015   #1203
Re: Project Lex
Got the seats today after a slight boondoggle of them being shipped to the wrong address. None the less, I have them and the brackets. I unwrapped them quick just to check em out. I think they look great. I sat in one and it felt perfect. Very comfy, bolsters on the bottom part aren't over sized so they're easy to get in/out of. The side bolsters for the upper torso area are a great fit, not too snug, but not overly loose either. Also I was pleasantly surprised to find out the reclining uses a lever. I thought I'd have to deal with a dial like on the Evo 8 seats. The lever will make for much easier/quicker reclining when taking the kid in and out of the back seat. You'll also notice I paid the extra couple bucks for the upgraded dual slider brackets rather than the single slider.
Hope to get at least one of them installed over the next couple weeks!
ID:	15418   Click image for larger version
ID:	15419   Click image for larger version
ID:	15421   Click image for larger version
Old 08-28-2015   #1204
Re: Project Lex
Those look nice. Black seats might look odd though.....
Old 08-28-2015   #1205
Re: Project Lex
You should just have me drive you around to help blend them into the interior.
Old 08-28-2015   #1206
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: Project Lex
The seats look nice.
That lever is nice. Those dials are one thing that is kinda a pita to deal with as a passenger, takes forever to recline!
Old 08-28-2015   #1207
Re: Project Lex
Those will be nice! Going to replace the carpet first before you stick them in? Or dye it black?
Old 08-28-2015   #1208
Re: Project Lex
Brownman, did you miss the part where I'm redoing the interior this winter to a new color scheme?
Peter, I'll be doing that this winter. The seats in general were planned for this winter, however since I'm going to try and race at PG, thought it might be nice to take advantage of the weight savings these offer so going to do the seats a little sooner than originally planned. Plan is to just dye it black. I have been reading how heavy the stock carpet is though, so there is actually a good amount of weight savings to be had by replacing it (30ish lbs savings) So I'm considering that, but at the same time if it weighs so much because it's helping insulate the interior sound wise, I hate to replace it just to have it ruin the quietness inside that I'm really enjoying.
Old 08-28-2015   #1209
Re: Project Lex
yeah my bad.
Can't wait to see it done.
Old 08-31-2015   #1210
Re: Project Lex
Passenger side is in!
So I had read about how bad a lot of these seat brackets were, so I was expecting install to be a little bit of a PITA. Well I was wrong, the Corbeau brackets fit perfect. 4 bolt holes to attach to the seat lined up perfect. The 5 holes that go to the stock location lined up perfect as well. Install was an absolute breeze!
I also busted out our highly inaccurate bathroom scale. I weighed the stock passenger seat at 56.5lbs. I weighed the replacement seat at 29lbs and the bracket at 11.5lbs. Not quite the weight difference I expected, but again this is my chinese bathroom scale. I also predict the stock drivers side seat will be heavier and be a more significant weight savings.
The seats fit in the car great, feel comfy, a hair more difficult to get in/out because of the torso bolsters but really not that bad. Overall very good first impressions, couldn't be more satisfied.
Only negative things are that the seat belt clip sits a little high, but whatever I'm sure they have it like that to clear the worst case scenario seat with super high bottom bolsters. And also it takes a little bit away from the sleeper-ness of the car, but that's kinda to be expected.
Bosses stamp of approval. Pregger Wife even said it felt snug yet comfy, and she's packing an extra person right where those bolsters are!
ID:	15428   Click image for larger version
ID:	15429   Click image for larger version
ID:	15431   Click image for larger version
ID:	15432   Click image for larger version
Old 08-31-2015   #1211
Re: Project Lex
Was that your official announcement for child number 2? Congrats!
Old 09-01-2015   #1212
Re: Project Lex
oh haha, it's not a secret or anything and thanks!
Old 09-01-2015   #1213
Re: Project Lex
Looks great! Race mode engage!
Old 09-01-2015   #1214
Re: Project Lex
20+lbs per side is awesome!
Old 09-03-2015   #1215
Re: Project Lex
Drivers side is in! Drivers stock seat weight a bit more, 68.5lbs. New seat was the same weight of about 40lbs with brackets. So 28lbs savings, plus 16lbs savings on passenger side, total of roughly 42lbs. Not as much as I had expected, but still a nice weigh loss. And I think I'm going to like these seats better than stock, win win!
Here's some pics. I'm glad this car has the auto steering wheel retract when you turn it off since you do have to lean forward a little more to get in/out. Makes it an absolute non-issue.
ID:	15443   Click image for larger version
ID:	15444   Click image for larger version
ID:	15446   Click image for larger version
ID:	15447   Click image for larger version
Old 09-03-2015   #1216
Re: Project Lex
Looks gangsta!
Old 09-03-2015   #1217
Re: Project Lex
Looks gangsta!
Gangsta lean! Exactly what I thought too.
Did it drop a ton in seat height?
Old 09-03-2015   #1218
Re: Project Lex
seat height might be like an inch higher. there looks to be a couple washers i could remove to lower it a hair, but just going to rock them as is.
Old 09-10-2015   #1219
Re: Project Lex
Lets see how she runs at the track this weekend! Also maiden 'tow' voyage with the D-RT, so we'll see how it does as well.
Old 09-10-2015   #1220
Re: Project Lex
Like a picture straight out of Beverly hills!
