Old 03-28-2016   #41
Re: Mark's Talon
64mm!!
Hot damn!
Do you have an ETA? I know you said you are waiting for the block and what not.
Old 03-29-2016   #42
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Re: Mark's Talon
Want it running by the end of April, but yea it depends when I get the block back.
BW8776, e-85
Old 03-29-2016   #43
Re: Mark's Talon
Very cool build, it'll be fun to see this thing in action
Old 03-30-2016   #44
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Thank you! Can't wait to make it to more events this year.. Definitely have a lot to do and learn.
BW8776, e-85
Old 04-26-2016   #45
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Spent all last night wiping down the bay with wax and grease remover. Spraying the bay tonight with primer, find all the flaws and fix them, then will come the color and clear. First time ever painting with a gun. Should be fun.
BW8776, e-85
Old 04-26-2016   #46
Re: Mark's Talon
Good luck!
Old 04-27-2016   #47
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
I'm honestly very happy with how it turned out. I think I figured out a good spray pattern/ gun control. Granted this is just primer and color and clear will be trickier. Might try and add a little reducer to see if it lays down a little smoother. Only one f-up when my sweatshirt dipped into it on the front clip area.
BW8776, e-85
Old 04-30-2016   #48
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Got my block back! Just need a few timing components and it can be assembled! Then mostly just waiting for the manifold and wastegates which should be here within a week or two.
BW8776, e-85
Old 04-30-2016   #49
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
And the bay is also now black! Things should go together quickly now..
BW8776, e-85
Old 05-04-2016   #50
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Got both subframes and all the rear suspension back in. Put in the windshield wiper assembly and the brake booster/ clutch master and brake likes.. Starting to look like a car again. Routed the harness (just have to get a way to mount the harness to the body)
Going to start putting the engine together tonight.
Still got high hopes to make it to PG's
BW8776, e-85
Old 05-04-2016   #51
Re: Mark's Talon
Looks awesome!
Old 05-19-2016   #52
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Looks awesome!
Thank you!
Engine and Trans are going in tomorrow. Been sick so hoping I got some energy.
Still waiting on my exhaust manifold from JMF, it should be here within a week or so.. Can't wait to see how it looks!
BW8776, e-85
Old 05-19-2016   #53
Mark Leasure
Mark Leasure's Avatar
Re: Mark's Talon
Looks great, fresh paint is awesome. Interested to see how the turbo works out! Get it out for prooving grounds.
www.maperformance.com
Old 05-21-2016   #54
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Thanks Mark! I'm actually pretty surprised on how well the paint layed down and how it turned out as it was my first time ever with a paint gun. The plan as of now is to make it up to PG on at least low boost. . I'm beyond excited to see how this turbo compares to the 20g!
Well the engine/ Trans are in.. The wiring harness is in and for the most part connected.
Gotta weld the IAT bung into my upper IC pipe.
Once I get the manifold I'll have to find a radiator that fits.
Just a few more gaskets to go
BW8776, e-85
Old 05-28-2016   #55
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Got the intake and the rest of the harness hooked up. Also got my fuel stuff on.
Still just waiting on my manifold from JMF. Ordered a scirocco radiator to fit in the core support and some Aerocatch hood latches to keep the hood down since the stock latch will need to be removed.
BW8776, e-85
Old 05-29-2016   #56
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Valve cover and front mount make a huge difference.
BW8776, e-85
Old 05-30-2016   #57
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Re: Mark's Talon
I got mine all back together and got her fired up! Better see this thing at Proving Grounds!
Old 05-30-2016   #58
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Hell yea you will. Hooked up the battery today and turned the key to the "ON" position and everything had function!
BW8776, e-85
Old 05-31-2016   #59
Re: Mark's Talon
Looks super clean! Good luck at proving grounds!
Old 06-01-2016   #60
mark4g63t
mark4g63t's Avatar
Re: Mark's Talon
Thank you. I'm getting close now.. Hoping I can install these hood latches properly the first time!
BW8776, e-85
