Old 06-02-2016   #1
jeremy1375
jeremy1375's Avatar
I need 2 junk front axles for 1ga ASAP
It's for a 1990 awd 1ga. I'm pretty sure fwd axles would work too.
At a minimum, I need the spindle side of 2 axles to bolt into the spindle to support the bearing.
I tried rolling my shell down the driveway without front axles and the bearing broke on one side - causing the wheel to fall off. Now it's stuck in the middle of my driveway.
Hoping to find something cheap.
Old 06-02-2016   #2
b00sted_spyder
Re: I need 2 junk front axles for 1ga ASAP
Use a long big bolt with 2 large washers and a nut. 1 washer on the outside and the other on the inside.
Old 06-02-2016   #3
jeremy1375
jeremy1375's Avatar
^That's a much better idea. Thanks
