Old 05-04-2018   #961
Re: Mark's 1G Winter Projects
So So Nice! Amazing work!
Old 09-04-2018   #962
Mark Leasure
Mark Leasure's Avatar
Had a good time this week with the dyno session and at the drag strip tuning before the Maperformance Proving Grounds the weekend of the 14th. Map's dyno was not reading my ignition, so unfortunately no published HP numbers. First pass off the trailer and ran very good for the new setup!
http://www.youtube.com/watch?v=QwPM1Bt2z5E&hd=1
http://www.youtube.com/watch?v=kU_Amap7O8k&hd=1
www.maperformance.com
Old 09-04-2018   #963
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Show gets real rowdy past the 60ft oh my! The cage turned out beautiful by the way....nice seeing you surrounded by it!
Old 09-05-2018   #964
Dark2g
Drives: 2gb gsx
Very nice bud!! That was a solid pass for right off the trailer. I will stop and say hi at pg, I didn’t register for as much so I should have some time to screw around. You gonna be up there on Friday I am assuming?
Old 09-05-2018   #965
Badass!
Old 09-05-2018   #966
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
So is that a new record right off the trailer on the new setup for you? Or is your signature out of date?
Either way, awesome job, the car looked like it was hooking well.
Old 09-05-2018   #967
Mark Leasure
Thanks guys!
Yep, new personal record for me on the first pass out! PG2 should be a good for more records too! I'm turning the boost up and I'll chop the 60 down too.
Old 09-05-2018   #968
Mark Leasure
Please delete
Old 09-05-2018   #969
Congrats! That is awesome.
Old 09-05-2018   #970
MorningWood
Drives: Evo 8, 2014 Silverado
Gotta love it when all the hard work pays off with a new PB, Get the 60' dialed in and you're going to be knocking on the door of 7's! Insane!
MorningWood is offline   Reply With Quote
Old 11-25-2018   #971
Mark Leasure
PG2 was not great for me, I cut a 1.31 60, and a shifter clip came off not allowing me to shift into 2nd, the engine reved high and tweaked like 12 valves. I broke 2 transfer cases in 2 passes...had a small fire when I raced nate in the semi finals too. These stock transfercase gears suck at my power level!
I've been watching for results of the magnus transfer case gearset. From my understanding no one has broke a set, with lots of 7 second passes! Christmas came early, I'm ready for next year! The most expensive part I've paid for on my car, I seriously have the most understanding wife.
Old 12-02-2018   #972
MorningWood
Hopefully that is the end of the Transfer case woes!
Old 12-02-2018   #973
That thing is badass! Good luck!
Old 12-05-2018   #974
:drool:
Good luck in 2019!
Old 01-28-2019   #975
Dang, you tell your wife how much car parts cost? ����
Old 01-29-2019   #976
dogwhistle
dogwhistle's Avatar
Rooting for you man! Can't wait for this year and your results.
-Adam
aneujahr@maperformance.com
Old 01-31-2019   #977
Mark Leasure
Thanks guys! Yep my wife knows how much it was.. I'm really looking forward to this summer!
