Old 08-07-2004   #1
JustROLLIN
SpunBearing
JustROLLIN's Avatar
I am trying to put my axles back into the car now that I have the tranny all back in place. (Thanks to everyone who gave out advice on that) But, I cannot get the tie rod to drop out. I do not have a puller and I am a little nervous about just smashing the top of the stud with a hammer. Any other suggestions or ideas. Thanks!
Old 08-08-2004   #2
LightningGSX
Hellbound
Thread the nut on %90 of the way and pound on that.
-Nulli Secundus-
Old 08-08-2004   #3
JustROLLIN
SpunBearing
JustROLLIN's Avatar
I am gonna disagree with you on this one. I have seen that cause some major thread issues. I have seen it work and seen it fuck up threads very badly. I dont have time or money for an alignment if I had to replace one of those tie rod ends.
Old 08-08-2004   #4
john
Business as usual
john's Avatar
Get a fork or rent the puller set at checker. I used both on ghettostyle's car. The pullers work awsome. The fork is OK but you can damage the parts if you are not carefull.
97 Viper GTS
Old 08-08-2004   #5
jd1828
Send a message via AIM to jd1828
if you not planning on replacing them then just rent a puller. if your are then use a torch to heat it up and give it a little tap. it will fall right out, but it will melt the boot off.
jd1828 is offline   Reply With Quote
Old 08-08-2004   #6
LightningGSX
Hellbound
I've done it a million times, never fucked up a single thread.You don't have to pound hard, with the nut on there, all the force is centered downward on the stud(so long as you hit it flat).Use the flat side of a pall pein hammer it works perfect.
-Nulli Secundus-
Old 08-08-2004   #7
LightningGSX
Hellbound
Worst case if you did screw up the threads, just count the turns taking the tie-rod end off, and then put the new one on the same number of turns.No alignment needed.
-Nulli Secundus-
Old 08-08-2004   #8
91 tuner
Use a hammer and hit the end of the knuckle where the tie rod goes into that should do the trick.
91 tuner is offline   Reply With Quote
Old 08-08-2004   #9
jd1828
ive never messed up the treads and ive beat on them with a 10lb hammer. as long as the nut is on. tie rod ends are cheap anyway. i think mine were $12 from bumper to bumper.
Old 08-08-2004   #10
Raptor
ConArtist
Raptor's Avatar
None of you are ever working on my tie rods :razz2:
Go rent a tie rod press. It will be the safest, least amount of headache, less chance for damage, and not very expensive way to go. Pickle forks work but are a major PITA unless they are attatched to an air hammer and then you still do damage to the joint usually. Heat should always be saved as a last resort due to the collateral damage it can cause. I have seen all your methods mentioned work and fail as well, when they fail it is expensive and happens often enough to not make it worth the risk. The other method sort of mentioned was to hit the knuckle with a hammer, I have only seen that work when there was another hammer on the opposite side in effect pinching the tapered shaft out, it works so so but not as easily as a press.
Hope that helps.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 08-08-2004   #11
1g or 2g, ither of which you do not have to break the tierod end out, just unbolt the knuckle from the strut, then turn the wheel all the way to the right for the passanger side(left for driver side) and it will come out of the tranny first, then you can pull it out of the hub. Or a 2g you undew the two lower controll arms and it will swing out far enough.
Old 08-08-2004   #12
Raptor
ConArtist
Raptor's Avatar
undew? Hahahaha. :stick:
651-488-7774
Old 08-08-2004   #13
so undew is like not 'doing the Dew' So would that be like drinking coke?
Old 08-08-2004   #14
LightningGSX
Hellbound
www.iespell.com
Your welcome.
-Nulli Secundus-
Old 08-08-2004   #15
Raptor
ConArtist
Raptor's Avatar
Okay, back on topic losers.
651-488-7774
Old 08-09-2004   #16
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Wow, lots of replies. I just ended up buying a 10 dollar puller from Auto Zone. Worked great, but thanks for the help anyway.
