Go Back   MitsuStyle > Hosted Support Forums > JET's Customs
Old 08-11-2004   #41
Is the manifold on the quest steel or cast iron? If it is cast steel it wouldn't be a problem, if it is cast iron I can weld it, but there won't be any guarantees. It likes to crack near the weld on cast iron, especially when heated and cooled a lot. It wouldn't be very expensive. I don't do turbo rebuilds, there is a place on the SW side of the cities that does. It is a diesel shop I think.
Isn't the 17c a mitsu turbo? It uses an 8cm exhaust housing if I remember right and a TD06 compressor side. Flow should be ~10% more than a 16g (similar to a B16g).
Old 08-11-2004   #42
Kougar
Drives: 06 RSX
Unfortunately it's made of cast iron
I believe this model of 17c has the td05 also, and although it's a mitsu turbo it comes off a cyclone/typhoon.
Old 08-11-2004   #43
Well, the weld "should" hold for quite a while, but I like to under-promise and over-deliver. I will probaly V-notch the weld to give it more surface to grab onto. Cast iron has a lot of impurities in it too, so it likes to cause porosity in the weld. It may not look quite as pretty as normal.
Is there a reason why you wouldn't just get a B16g? I am guessing price, but I have seen them pretty cheap since can get a new one for like $535.
Old 08-11-2004   #44
Kougar
Drives: 06 RSX
Well the 17c was my 'dream' turbo, in terms of moderate size combined with fast spool. I wasn't intending huge boost, just something in the middle i guess.
But yeah, a S16g is a better choice in this case i believe, and even saying that, I don't know if im going to keep my car so i probably shouldn't start another stage of modding.
Old 08-21-2004   #45
b.a.
Guest
Tournaments Won: 6
Posts: n/a
JET, I PMd you a while ago about some porting on a 14b and o2 housing but haven't heard back. I'm still interested if you have the time, PM me or call my cell, the number is in my PM to you. -blake
Old 08-21-2004   #46
illz
get the super16g pile of crap out of here
Old 08-21-2004   #47
17c? S16G? Is this 1999? Those turbos are terrible.
Old 08-22-2004   #48
Kougar
Drives: 06 RSX
...I do hope you're kidding.
Not all of us want HUGE drag set-ups on our cars. These "small, outdated" turbos are perfect for a lot of people.
Old 08-22-2004   #49
What they are saying is that there are much more efficient smaller turbo's out there. Like a Evo 16g or B16g.
Alright, now back on topic or make another thread!
Old 10-28-2004   #50
speedfreaktalon6
i was wondering how much it would be to port and poslid a head, intake, and also if you can bore out an engine block to a .30 over? pm me back
speedfreaktalon6 is offline   Reply With Quote
Old 11-05-2004   #51
Can you make a 2G MAS to cone filter adaptor? I see Extreme Motorsports makes one but $60 bucks seems a little on the high end.
Old 11-06-2004   #52
I think they go for like $15 online and at shops besides Extreme.
Old 04-13-2008   #53
bob123131
Re: Porting Services
Wondering if you are doin valve job's yet? and can you deck heads, i have already stage 1 ported head i would like to get this done too.
Old 04-13-2008   #54
Nope, I don't do the actual machine work.
