Old 11-10-2004   #1
stikx
Mr -
After timing belt job engine sounds weird???
well after the timing belt job and change of the water pump and pulleys...the motor started to sound weird, like the motor is running harder than it use to. it makes like a hard noise that is louder than it use to be...dont flame me if its something stupid :P
Old 11-10-2004   #2
Enes
Enes's Avatar
hello new heaad work but hopefully not.. as well as new timing belt job..
double/tripple check your timing marks make sure its right on..
1g or 2g?
who did work?
more details will be needed here..
its like saying it stinks here and i just sat next to something.. why is it wet?
-E
Old 11-10-2004   #3
Does the car vibrate like mad? That can be an off balance shaft. Happened to me, was opposite what it should have been but still was "lined up." Made the car impossible to drive aboe 2500rpms.
Old 11-10-2004   #4
HondaKiller
HondaKiller's Avatar
My car was like that when I bought it too, set to TDC and stick a screwdriver in the hole in the back of the block to check it.
The engine will rev but there is a loud vibration sound.
HondaKiller is offline   Reply With Quote
Old 11-10-2004   #5
stikx
Mr -
its a 2g yea its like a vibrating noise from the motor? Just got a new timing belt job, some local shop did it. Wheres the balance shaft located?
Old 11-10-2004   #6
HondaKiller
If you look at the back side of the engine block from underneath there is the head of a bolt that is on a flat spot. It looks out of place since it isn't holding anything on. Just take that out and stick a screw driver into the hole, it should go all the way in, if it just goes in about a half inch, the balance shaft is in backwards. This must be done with the engine at TDC of course.
But fix it right away, on mine it vibrated so bad it snapped the heads off two of the transmission bell housing bolts...not fun trying to drill and tap those holes with the engine in the car.
