Old 01-07-2005   #1
wohlfman
Professional Rumprider
Send a message via Yahoo to wohlfman
1G Auto to Manual Swap
What can I use off of a 93 AWD laser 5 speed, to a 92 Eclipse GSX automatic.
I am putting a manual in the GSX.
Mike WohlfeilMike Wohlfeil
wohlfman is offline   Reply With Quote
Old 01-07-2005   #2
Re: Question
Well, I'd start with everything related to the manual transmission. Its a fairly big task, I'd rather swap an engine that do a AT to MT swap. Tranny, pedal assembly, shifter and shifter cables, clutch lines, clutch master and slave cylinders, etc. Also keep in mind there are engine differences between the AT and MT cars, they have different ECU's, fuel injectors, turbos, and exhaust manifolds. I'd deffinately swap all that stuff on too. Whats wrong with the Laser and why are you doing this?
Old 01-07-2005   #3
Re: 1G Auto to Manual Swap
Thread re-named and moved to advanced tech. The reason I put this is advanced tech is because he is asking about switching more than just the transmission and drivetrain.
CRAIG
Old 01-07-2005   #4
Re: Question
Mike's Laser has a salvage title and no first gear versus the GSX is spotless (from what I recall) and has a clean title. The Laser he has was posted up for sale on here last summer by it's former owner if that rings a bell.
Old 01-07-2005   #5
wohlfman
like stated earlier the laser has a salvage title, and the GSX I have is spotless. I love working on my cars, and being in the garage. The GSX is my baby, and it could be an interesting project, and to help me learn more. Plus it keeps me out of trouble up town.
Old 01-08-2005   #6
Anduinlight
The Ghey Chef!
Anduinlight's Avatar
Drives: 2007 Toyota Tundra
I know he didn't do it personally but Matt R (AlpineTSI) has a 92 Talon that was AT to MT converted, and I believe he is fairly well versed in what all is involved in doing doing it.
98 Mitsubishi Eclipse RS - Gone
92 Eagle Talon TSi AWD - Parted out
10 Toyota Camry - DD
07 Toyota Tundra - For pretty much everything else
Anduinlight is offline   Reply With Quote
Old 01-09-2005   #7
wohlfman
Thank you very much.
Old 04-20-2005   #8
Re: Question
I was looking at the VFAQ on this and its showing that you Do NOT need a new ECU, Injectors, Turbo, or Exhaust manifold.
Im looking into this because it will be done within the next month on my car. Is there any major Differences in the parts needed for a 2g?
Old 04-20-2005   #9
Re: Question
There are no differences in 2G cars, just the 1G's.
Old 04-20-2005   #10
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Re: Question
You could do it without the above stuff, but you would be using a smaller turbo, smaller injectors, and a worse manifold. Also the AT cams are strong in the mid RPM band, where the MT cams are strong at the high RPM band(as strong as stock cams can be).
If I were to do the swap on a 1G I wouldn't do it to stock MT parts though, I would upgrade from there(2G exh mani, 550's or bigger, 16G or bigger, EPROM ECU). To me it doesn't make sense to upgrade from AT to MT parts while doing the swap unless any of the parts were bad or you had a good line on those parts for cheap and working well.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 04-20-2005   #11
As stated in Tom's NAME, he drives a 2G which do not have differences like 1G's.
Old 04-20-2005   #12
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I'm more than aware of that, I was stating it for those who were interested and so they knew the advantages/disadvantages of leaving those parts in.
Also, that is why I mentioned if I were to do the swap in a 1G....
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 04-20-2005   #13
Then you shouldn't quote Tom's question about 2G's when referring to 1G's. You're going to confuse the kiddies.
Old 04-20-2005   #14
Raptor
ConArtist
Raptor's Avatar
Somewhere in this, you also should note the rear diff gearing is different in the Auto. So that needs to be changed as well. Some other things to consider are the wiring for the reverse lights, neutral safety etc. Eric likely has the details on those things, he took care of it when we did DJ's conversion a few months ago. There is some cutting on the firewall etc to do to mount the clutch master cylinder as well some creativity involved with the cable install. Not a small project by any means.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 04-20-2005   #15
You need:
*assuming both vehicles are completely stock.
-Transmission w/shifter brackets/etc.
-transfercase
-rear end assembly (atleast the diff, maybe a 4 bolt upgrade if the axles are different).
-slave cylinder
-line from slave cylinder assembly to clutch pedal
-clutch master cylinder assembly (firewall modifications required, as raptor mentioned)
-clutch/flywheel
-starter plate? (not sure on this one but I think they are different
-cams
-exhaust manifold
-turbo w/lines
-injectors
-fuel pump? (again, might be the same)
-ecu
obviously all the reverse wiring sensors/harness/clutch sensor, etc..like raptor mentioned
-shifter cables
-shifter base
-center console
-pedal assembly
Thats all the stuff that has to be 'swapped' or replace I can remember off the top of my head.
Its not an easy task, or a quick one. Good luck.
Old 04-21-2005   #16
Mike if you dont mind, What was the total damage (in $s) for doing a AT to MT swap parts included. I would like to get this done in the next couple weeks but i would like something to reference price wise.
Old 04-21-2005   #17
I believe Mike did it for free since he likes DJ's perty mouth so much. Maybe I'm wrong, but we all know DJ is broke and Mike is lonely!
Old 04-21-2005   #18
I didn't think DJ was that good, so he only got the discounted rate. And he had to supply the parts car. There might have been another stipulation that included the tumbler as well but I could be wrong.
Tom, your probably best off getting a parts car and estimating 2-4k in parts and labor.
Old 04-21-2005   #19
Raptor
ConArtist
Raptor's Avatar
If that were to happen again here, it would be around 2000-2500 in labor(1G). DJ got a really good deal, not for the reasons you fucktards mentioned. I would never do it for the same rate again. The cheapest way to do it is for sure to pick up a parts car, at least then, you could sell some of the stuff you didn't use to offset some of the labor costs as well.
AJ is the perv who likes the tumbler, he mentioned several times that he would fit inside it. Don't know if he tried it or not, don't really want to know.
651-488-7774
Old 04-21-2005   #20
Thanks, Hopefully i can get the setup and have it done within 3-4 weeks
