Old 01-12-2005   #1
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
Yellow snow? rear leaking?
Ok so my car has been sitting out for the past few days and when I go to put it in tonight I have a yellow circle under the rear lsd, about 10" in diameter in the snow. What's up with that?
Khadgar is offline   Reply With Quote
Old 01-12-2005   #2
Sean485
Guest
Tournaments Won: 6
Posts: n/a
Re: Yellow snow? rear leaking?
Gas leak?
Old 01-12-2005   #3
Feel the snow, does it feel oily at all? Maybe the rear diff is leaking.
Old 01-12-2005   #4
Khadgar
It feels frozen =/, it is one with the ice now.
Old 01-12-2005   #5
well, it shouldn't be oil then. I would say it is dog piss
Old 01-12-2005   #6
Khadgar
Maybe it just feels frozen since it dripped on to pure ice?
Old 01-12-2005   #7
When in doubt, smell it.
Old 01-12-2005   #8
Khadgar
http://www.corporatefallout.net/100EPSON/
Here are some picutres of it.
Old 01-12-2005   #9
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Wouldn't piss have melted that area too? You know like left an indentation or something. That must of been something that wasn't warm.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 01-12-2005   #10
yeah, it looks kinda dark. A lot like gear oil. I would check it out pretty soon.
Old 01-12-2005   #11
Yea that is a pretty big circle, I would look into that before you loose much more.
Old 01-12-2005   #12
Khadgar
I dont drive her often, been sitting there for a week or two, any idea why it might leak?
Old 01-12-2005   #13
The cold is pobably shrinking the seal around 1 or both of your axles, which would make it leak, or the metal contracted a little around the plug and some leaked out... but then more would have leaked out.
The cold weather shrinks all rubber gaskets/seals so everything leaks easier.
Old 01-13-2005   #14
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Just look at your pinion seal and axle seals, if they're coated in slime they're leaking. Should be pretty obvious if it is leaking.
Old 01-13-2005   #15
Khadgar
Rgr that.
Old 01-16-2005   #16
Khadgar
WTF, it's coming from my trunk, must be wiper fluid, even tho the stuff have in there in green, is it possible it froze and cracked the ressy?
Old 01-16-2005   #17
That stuff shouldn't freeze unless you put some water in the reservoir.
CRAIG
Old 01-16-2005   #18
Your positive its not gas? Did you smell it?
Old 01-16-2005   #19
Khadgar
It's in my trunk and I can see where its dripping out the drain hole.
Old 01-16-2005   #20
Maybe the hatch is leaking?
