Old 03-24-2005   #1
JiggahMan
Power troubles
Hey, I'm having trouble with my power.. A few weeks ago my seatbelts started to not go back an forth untill the engine is turned on. I mean the engine is running not just putting the key to the on position. Plz help! It sucks when I turn the car off and try to get out!!
JiggahMan is offline   Reply With Quote
Old 03-24-2005   #2
JiggahMan
Re: Power troubles
Also, I am unable to use my alarm.. The way it's beeping means a sensor is malfunctioning.
Old 03-24-2005   #3
Anduinlight
The Ghey Chef!
Anduinlight's Avatar
Drives: 2007 Toyota Tundra
Re: Power troubles
you should bring it to an auto zone and have your battery and alternator tested. Also Is it just your seatbelts or is it other things too? And as far as the alarm goes, do you have the manual that tell you what each beep means. It might be beeping to tell you that the battery is going dead.
98 Mitsubishi Eclipse RS - Gone
92 Eagle Talon TSi AWD - Parted out
10 Toyota Camry - DD
07 Toyota Tundra - For pretty much everything else
Anduinlight is offline   Reply With Quote
Old 03-24-2005   #4
Anduinlight
The Ghey Chef!
Re: Power troubles
or if you have your own multimeter you can test your battery yourself. should be about 12.6v DC resting and 14.4v DC when it is running
Old 03-24-2005   #5
JiggahMan
Re: Power troubles
My alternator's out and I haven't gotten it fixed yet.. Just been taking it out and charging it indoors every night. The alarm was installed by the guy that had the car before me. I've looked into the manual online. It talks about an LED light that says which sensor is malfunctioning, but there is no LED in the car. *shrug*
Old 03-24-2005   #6
JiggahMan
Re: Power troubles
Could the dead alternator be causing these problems?
Old 03-24-2005   #7
Anduinlight
The Ghey Chef!
Re: Power troubles
oh yeah :/ anything power realated will be affected by a dead/dying alternator.
<--- so does that mean your runnig your car on just battery power? That I'm sure is not very good at all for the battery. because while your driving, your battery would normally be charging the battery. Since you don't have one in your battery will slowly drain and die, which will leave you stranded where ever you are.
Old 03-24-2005   #8
JiggahMan
Re: Power troubles
Meh, batteries are cheap and can be replaced in less than a minute. Not worried about mine, just want to make sure my car's alright. I have an alternator already sitting in the garage, maybe it's time I get off my a$$ and do it.
Old 03-24-2005   #9
Anduinlight
The Ghey Chef!
Re: Power troubles
should only take ya like 30 minutes if that to put it in
Old 03-24-2005   #10
Re: Power troubles
Yea maybe it is time to get off your butt and install the alternator... For every 15 minutes you take your battery out every night and charge it and reinstall it you could have spent an hour and just replaced the alternator?? Kinda retarded logic but whatever.
Batteries are not that "cheap" either if you want a quality peice. Ussually around 50 bucks.
You should probably read the rules too and post about yourself...
Old 03-24-2005   #11
JiggahMan
Re: Power troubles
30? Looked harder than that to me. I guess I'm about to find out, though.
Old 03-24-2005   #12
Anduinlight
The Ghey Chef!
Talking Re: Power troubles
if you lived in shakopee I could give you a hand
(although you shoudl post in the new members area still, so at least we know who you are)
Old 03-24-2005   #13
Re: Power troubles
If you are good you could install an Alt. in under 10 minutes. They are very easy on a DSM. At least something is!!
Old 03-24-2005   #14
JiggahMan
Re: Power troubles
The only thing I'm worried about is how to do the belt.. Does it slip right off and just pull it back with the ne alternator or...
Old 03-24-2005   #15
Re: Power troubles
Alternator is a very easy thing to accomplish on a DSM. Put it on and tighen the belt is reverse order of how you took the old one off. The belt needs to be tight enough to no slip/squeak, but not so tight it wrecks the bearings. After you install it, at idle turn on the headlights (highbeam), AC with full fan, and your rear defroster...if its going to slip/squeak now will be the time.
Old 03-25-2005   #16
LightningGSX
Hellbound
Re: Power troubles
What brand alarm?
-Nulli Secundus-
Old 03-25-2005   #17
Raptor
ConArtist
Raptor's Avatar
Re: Power troubles
I am not sure I believe this is a real tech question. Are there really people like this or am I just expecting too much. This is Hughes pretending to be stupid again isn't it? Come on fess up. Jiggahman? seriously.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 03-25-2005   #18
Re: Power troubles
With what I've been seeing on the board lately this doesn't really phase me...and no, LunarEclipse has died with no beneficiaries or next of kin.
Old 03-25-2005   #19
Re: Power troubles
Old 03-25-2005   #20
JiggahMan
Re: Power troubles
Originally Posted by LightningGSX
What brand alarm?
Clifford.
