Old 05-04-2005   #41
Nash
Nash's Avatar
Re: After all the abuse...
Originally Posted by DSMStyle
ohhh, sexy! Can I have the broken shit? PLEASE!
no.
Old 05-04-2005   #42
Originally Posted by niterydr
I believe he is referring to the cylinders cracking under load and power, not rods beating the shit out of it...
Yep.
Old 05-04-2005   #43
Yeah, it looks like the wrist pin seized up in the piston. Notice the bluing on the end of the rod and there are small cracks in the piston around the wrist pin. Nash, is the #3 cylinder the one with the broken oil squirter?
Old 05-04-2005   #44
Now let's hope we don't get the rash of cracked cylinder walls that are plagueing more and more DSM'rs around the country with 2.4 blocks.
It is 2.0ls also. Mostly seems to be guys making 550whp+ on either block. Or at least on 6-bolts.
Old 05-04-2005   #45
I would guess it spun the rod bearing then cut oil off to the wrist pin, thus breaking the rod etc.
Old 05-04-2005   #46
Bzzzt... The rod bearing is perfect, the rod falls back down just from gravity when you pick it up. The wrist pin just seized for some reason.
Old 05-04-2005   #47
Nash
Nash's Avatar
It looks like it to me.
Old 05-04-2005   #48
Raptor
ConArtist
Raptor's Avatar
The pin is thermal fit so it is intentionally siezed The piston pin gets oil off the cylinder wall, the rod journal just puts a stream of oil on the wall as well. It isn't a direct feed or only source for the pin.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 05-05-2005   #49
Good luck with that, let us know how that holds up.
Originally Posted by Nash
Oh yeah, and I'm going to have Jet weld up the hole in block. Be just as good as new.
Old 05-05-2005   #50
Hess had a 2.4.
Originally Posted by Jakey
Was Hess' a 2.0 or 2.4?
I wonder if cryo treating blocks would made a significant difference with the cracking issues.
Old 05-10-2005   #51
ZelpDSM
Guest
Tournaments Won: 6
Posts: n/a
Wow, I didn't think that thing was still running. Did you really push 530HP out of it? It says 91 on the Elite list and that was a 90. Anyway, excellent work with that car Andy. Best of luck with your next project.
-Patrick
1990 Suzuki Samurai
Old 05-10-2005   #52
Nash
Nash's Avatar
-Patrick
1990 Suzuki Samurai
Thanks again for such an awesome deal! The car did end up putting down 531 fwhp, not bad for stock internals. That was the best $360 I have ever spent!
