Old 06-17-2005   #1
ther1pper
ther1pper's Avatar
Send a message via AIM to ther1pper
Weird studder when floor the peddle: pls help
hey.. i have a 98 gsx, and like i got this car and like i was driving it, and like it started to studder alot when i press the gas hard, it like jerks alot like its not getting gas to the engine or some shit, i have had like 4 or 5 people ride with me to try and figure it out, someone said it might have something to do with the injection system, but im not sure, anyone had a idea???? if u know what im talking about?? pls help
ther1pper is offline   Reply With Quote
Old 06-17-2005   #2
Re: Weird studder when floor the peddle: pls help
How violent is this jerking? Are you running stock boost? It could be fuel cut, meaning you're running too much boost, not enough fuel, and your car kinda shuts down for a second, then kicking back in, causing a rather violent jerk. To correct that you'll need a better fuel pump.
Old 06-17-2005   #3
Like, check like your like plugs and probably like your plug wires too. More than likely, you need new ones of both.
Old 06-17-2005   #4
How exactly is just a fuel pump going to eliminate fuel cut?
Old 06-17-2005   #5
ther1pper
ther1pper's Avatar
the car never turns off tho, it jsut like jerks violently, i dont know, someone said it might be the fuel pump, but im running 9psi right now.. im not sure what stock is but yea.. anything?
Old 06-17-2005   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Try a Boost leak test. Seems as if you are getting fuel cut but yet arent seeing the air flow that would create it.
Go to www.vfaq.com and make yourself a boost leak tester and search for leaks. If you dont find any then go on to the next possible cause. Spark plugs/wires like was mentioned before! Good luck.
LMAO... That was well put!
Originally Posted by shoutbox
Old 06-17-2005   #7
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
A fuel pump will not eliminate fuel cut. Fuel cut happens when the computer sees too much air flow (from the mass air sensor located before the turbo) for the stock fuel system to keep up with so it cuts spark and fuel delivery to the motor. The only way around it (with a bigger turbo running more boost) is with either a computer chip, fuel controller or some sort of engine management. It would be pointless to do this on a stock fuel setup so there for you would want to upgrade your injectors and fuel pump while your at it.
You should not have fuel cut on the stock turbo at this time of the year running 9psi. There for it leads me to believe you have a boost leak but the turbo is still trying to boost the same amount of pressure into the intake. While trying to do that the air is just leaking out so the turbo is pulling in more air to make up for the loss. This is why you are only seeing 9psi.
Old 06-17-2005   #8
LightningGSX
Hellbound
Check the TPS.When the TPS is not functioning properly, you won't get accell enrichment, which pretty much sounds like your problem
EDIT: Definately start with new plugs and wires though.
-Nulli Secundus-
Old 06-17-2005   #9
deng, well I stand corrected. I had always understood that fuel cut was when your computer sees that you are running too lean, which in a lot of cases was usually caused by people pushing their little stock fuel pumps past it's limits. So by getting a larger pump, it usually helped in eliminating that. Guess I understood wrong, my bad. Sorry for the bad info.
Old 06-17-2005   #10
ther1pper
ther1pper's Avatar
ight thanks for the help... imma go get some new plugs and new wires and see how that works out.. ill report back eventually
Old 06-17-2005   #11
INTRIGUED
insert witty title here
INTRIGUED's Avatar
Drives: VW Gti
werd homie
Old 06-19-2005   #12
ther1pper
ther1pper's Avatar
hey just reporting back, ight so i went and got new plugs and new wires.. put them in.. went for a test drive and it fixed my problem... thanks for the advice guys
