Re: CV shaft is stuck in the hub
My drivers front CV wouldn't come out for the life of me. I started out like I normally do with a little bit of heat and then hit the end of it with the nut on with a hammer. Didn't work. Tried it again, with oil this time. No go. sprayed a bunch of knockerloose on and let it sit for a bit and tried again, no go.then, i took a 20lb sledge to it, with medium hits, no go. Heated the fuck out of it, oiled it, and took off the nut and smashed the shit out of it with a hammer probably 100 times and it didn't budge. The back of the CV joint popped off and broke the CV on one of the swings.
At this point I figured I'd be buying a new spindle anways, so I hit it as hard as I possibly could 20 or 30 times, and the damn thing wouldn't move. It was mushroomed out about 1.5 inches larger then normal. Pretty fun.
If yours is anything like mine, good luck to you.
But in all honesty, I would go buy and actual rust penetrant, NOT WD40. WD40 works about 10 percent as good as an actual rust penetrant. If you must get it out, thats your second best option.
Your best option is finding someone with an oxy-acetylene torch and some 5w20 motor oil. Heat the fuck out of the hub around it, and then drop oil on it, repeat about 5 times, and then it should come out easily.
420A > LS1 > All Else
I > All else
