Old 11-22-2006   #1
blesi660r
blesi660r's Avatar
crazy sway bar Q? need fast rep!
ok i am replacing my rear lower arm in the rear susp. the link joint that connects the rear sway bar to the arm,one of the bolts is really striped so i cant get it off, how will running with out a sway bar affect my car!
i know its a stupid question and i plan on geting the link repplaced asap! but the bushing on the arm is shot well thats an under statment
Old 11-22-2006   #2
blesi660r
blesi660r's Avatar
Re: crazy sway bar Q? need fast rep!
oh well i will replace it some other day!
Old 11-22-2006   #3
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
I know my friend with a WRX is running without a sway bar basically right now, you just get incredible body roll. I'm pretty sure it would be teh same with a DSM.
Good luck son and happy turkey day.
Old 11-22-2006   #4
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
its just gonna cause more body roll and and less handling.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 11-22-2006   #5
blesi660r
blesi660r's Avatar
thanks alot guys, and HAPPY turkey day to you guy's to!
Old 11-23-2006   #6
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
same for yourself! happy turkey day!
-Matt
'06 Acura TL
Old 11-23-2006   #7
I'm driving my 2g w/o sway bar links. Actually I have been for a few months and it's fine. Yes there is some body roll but you get used to it (sadly). I am planning on getting some performance sway bars in the future, so I'm just leaving it how it is till then.
Old 11-23-2006   #8
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
it happens...
-Matt
'06 Acura TL
Old 11-23-2006   #9
blesi660r
blesi660r's Avatar
ya! the sway bar links are what i am having trouble with, the dam thing is striped so i cant get it apart from the arm, and i cant find my dam vise grips! it's only the passenger side thats giving me hell!
Old 11-24-2006   #10
Break out the hack saw and buy some links...It's the only way. Next time, stick a screwdriver in behind whatever wrench you use to hold it in place so it does not slip as you tighten/loosen the nut on the other side.
Old 11-24-2006   #11
Do you need sway bar links if you have aftermarket sway bars? Or do they go together? Sorry if that's a noobish question.
Old 11-24-2006   #12
rst95eclipse
I had the same problem when I was disassembling my suspension. I had to cut 3 of the 4. Aftermarket sway bars do NOT come with end links. You need to purchase OEM. And they my friend are around $40-50 a pop. When or if you go in, please let me know. Maybe we can get some sort of deal purchasing 8 instead of 4.
Mine weren't stripped. They were just rusted beyond compare. I Liquid Wrenched those bitches, but with no avail. I think it's the design. You have to use (2) 14 mm open/closed wrenches to accomplish the job, and you must put an open between the ball joint and the nut (this metal is incredibly soft). Then you torque the nut off.
Old 11-24-2006   #13
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
oem endlinks work, it is nice to get new ones and not use the old anyways because the bushings tend to start cracking as they age.
-Matt
'06 Acura TL
Old 11-24-2006   #14
blesi660r
blesi660r's Avatar
ya i am acually going to replace the rear arm on the driver side at the same time! so i plan on going in on friday to brookdale mitsu "it's close to my work"
Old 11-24-2006   #15
blesi660r
blesi660r's Avatar
at the moment i am runing no sway bar i really cant feal a difference but yet i havent driven far!
Old 11-25-2006   #16
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
its not that big of a deal.
-Matt
'06 Acura TL
