Old 04-06-2009   #21
4seasons69
4seasons69's Avatar
Re: D16 Vtec + Megasquirt.
I believe the truck was MAP, I'm not seeing a MAF in any of the pics in the book.
getting egr at idle will make the car run like crap or kill regardless wether its a map or a maf car
Old 04-07-2009   #22
iceminion
iceminion's Avatar
yes, however, a wide open EGT will not cause the car not to accelerate at freeway speeds...Now the car cannot achieve freeway speeds.
Thanks for all who are concerned, however since the stock wiring harness is basically screwed (considerable modifications were made, that I am unwilling to fix) I am just going to megasquirt it, and call it a day.
Besides, this is an excellent platform to learn how to tune with.
building a 3000GT AWD Turbo.
Old 04-07-2009   #23
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
I still say you should fix it first and then standalone the car,
You are trying to modify a broken car! When you are first doing your tuning you are now trying to figure out if it is the car that is giving you the problems or if it is the MS system that is giving you problems!
All I see is a headache in the future trying to diagnose if the problem is the MS system or the car itself. That is just going to make the process 2X longer.
It could be the ECU but I don't think so
I pulled the plugs and they are black! black=rich
I am thinking a FPR is too high or something...
on a side note, I will help you convert the car when working. Did you get the MS1 or MS2?
