Old 08-09-2009   #1
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
here's a turbo for the v8/v6 crowd
I noticed this at work the other day, never seen a turbine housing like it.
I beleve it came off a Caterpillar 3208.
Sorry for the crappy phone pic.
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
Old 08-09-2009   #2
viridionplague
Re: here's a turbo for the v8/v6 crowd
where can i get one?
Old 08-09-2009   #3
I'm curious as to what the point of this is? Unless you have a twin plenum intake system on the engine, you would still have just one throttle body, which defeats the purpose of two outlets on the compressor housing.
Old 08-09-2009   #4
viridionplague
why couldnt that be the exhaust side?
Old 08-09-2009   #5
It looks like it's aluminum, so I doubt it could stand up to the heat of the exhaust.
Old 08-09-2009   #6
viridionplague
well to me it looks like its setup for v-band clamps, or whatever the quick exhaust clamps are called, if it was for intake clamps why would they cut a notch and roll the lip.
either way its hard to tell in the picture what its actualy made out of
Old 08-09-2009   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
To me it looks like an exhaust housing with a v-band inlet and v-band outlet. The compressor housing is sitting right next to it..
-1990 Mitsubishi Cyborg 4WD-
Old 08-09-2009   #8
Alot of heavy equipment uses v-band clamps on the compressor housings. Most of the pushbacks and other airplane moving stuff at the airport use them on both the intake and exhaust sides of the engine.
Old 08-09-2009   #9
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
I think it's an exhaust housing.
Old 08-09-2009   #10
It could be part of a sequential turbo setup.
Old 08-09-2009   #11
95tsi
95tsi's Avatar
Drives: a pos
twin intercoolers
Old 08-09-2009   #12
gofastman
gofastman's Avatar
Drives: 95 Jeep
Its the exhaust side. Its cast iron.
-David C.
Old 08-09-2009   #13
Must be freshly sandblasted that makes it look like aluminum.
Old 08-09-2009   #14
gofastman
gofastman's Avatar
Drives: 95 Jeep
I beleve it was run through an abrasive tumbler
-David C.
Old 08-09-2009   #15
helllllooooo spoolup. We should see this very soon on daily driver DSMs. I believe its streetable.
Old 08-09-2009   #16
john
Business as usual
john's Avatar
That is the exhaust housing.
97 Viper GTS
Old 08-09-2009   #17
If that's the exhaust housing then it would be two exhaust inlets to spin a single turbo. Pretty cool for a big engine.
Old 08-10-2009   #18
viridionplague
if i ever get around to my turbo mustang project ill look into one of these, and make a project thread
Old 08-10-2009   #19
blackrosenova400
blackrosenova400's Avatar
Caterpillar used compound twin turbo setups on there big dogs instead of using egr valves to pass epa 04 emmisions. I dont think they will be doing that anymore as the twin turbo setup will not be able to pass epa 07 emissions.
Old 08-12-2009   #20
gofastman
gofastman's Avatar
Drives: 95 Jeep
did they accidently the whole thing?!?!
-David C.
