Old 08-28-2009   #1
dsm2die4
Prisoner of Boost
dsm2die4's Avatar
Drives: A better POS than you
stuck in 3rd...tcu issue? help
So here's the deal:
Got a steal of a deal on a 91 tsi. Put a new water pump, tstat, t belt, and fluids in. Runs great now, IT JUST WON'T SHIFT OUT OF 3RD GEAR. It goes into park and reverse kinda hard, but in drive its really hard to start out and then it won't shift up or down at all with changes in speed.
I checked the transmission fuse and it's fine. I thought I ran a TCU diagnosis scan and got 14 which is for a TPS. Adjusted that, still nothing.
Any ideas on what to do?
Where can I find the TCU?
Anybody have another one I could try out to see if it works?
HELP!
thanks
dsm2die4 is offline   Reply With Quote
Old 08-28-2009   #2
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: stuck in 3rd...tcu issue? help
If it threw a code for the TPS I would try a different TPS that is known to be good.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 08-28-2009   #3
twack
It was a auto get over it
twack's Avatar
no if its in limp mode something is up with the tranny or the tcu if you got around $150 i can get you a shift box that will force the tranny to shift but you will be using the box to shift from now on. ill have a tcu for sale in under a month if you can wait
Old 08-28-2009   #4
123abc
123abc's Avatar
Drives: Loud cars
Also, did you check the fluid level? I know a lot of chrysler auto trannies will go into limp mode if there isn't enough fluid in.
Old 08-31-2009   #5
dsm2die4
Prisoner of Boost
dsm2die4's Avatar
thanks I'll check the fluid today.
Twack hit me up when that TCU comes around
Old 09-01-2009   #6
Are all the connectors for the tranny plugged in? There is one that controls the valve body, if its not plugged in the tranny will be stuck in 3rd gear.
