Old 12-17-2010   #1
All Sorts of Higher-Flowing fuel pumps coming onto the market
This is crazy awesome! The good'ol walbro 255HP has always been good at making great power, especially with a BAP behind it, but being able to skip the BAP and just drop-in a new pump that can flow pretty big numbers (even on E85) is just awesome! This thread will have info on all of them, feel free to add, especially if you have first-hand experience with any of them (including deciding to pick one up!)
Aeromotive 'Stealth' 340 ($190-ish?):
http://www.lsxtv.com/news/pri-2010-a...lth-fuel-pump/
DeatschWerks DW300 ($170):
Jay Racing PT342 ($150):
(click for high res)
I've also heard that Buschur is going to make their own (I'm sure it will be someone else's re-labeled though):
http://forums.evolutionm.net/8919621-post99.html
Price for all of these is in the $150-200 range, will be interesting to see people start using these!
Old 12-17-2010   #2
Re: All Sorts of Higher-Flowing fuel pumps coming onto the market
Pretty sure MAP said they were going to have something for sale similar to these soon as well.
Old 12-17-2010   #3
When are they going to make some nice pumps for Direct injection.
Old 12-17-2010   #4
Dang. I should have waited, lol.
Old 12-17-2010   #5
DI injectors + DI mechanical HP pump + LP electric in-tank = LOL $$$$$$$$
Old 12-17-2010   #6
DI injectors + DI mechanical HP pump + LP electric in-tank = TROLOLOLOLOLOLOLOL $$$$$$$$
FTFY
Ok, back on topic!
Old 12-17-2010   #7
haha, well done scheides. would read again.
Old 12-17-2010   #8
MAP is selling the DW pumps, I believe they just made 624whp on a dsm with a single DW pump.
I'll be hopefully throwing one of these in my car before the season starts next year.
Old 12-17-2010   #9
Nice. I'm still going to rock my dual wally setup. If I max it out, I may look at these. Would a pair of these provide high enough flow at higher fuel pressure to run some of these High-Z injectors at higher pressures to flow more? My injectors will probably be more my limit, but if I can find a simple way to run higher FP, then they should be able to support more.
Old 12-17-2010   #10
v8klla
v8klla's Avatar
We have tried the DW and its everything its cracked up to be, the aeromotives are not available(will start shipping next week) and we have not tried one out yet but I am sure we can them for something like $165ish. Either way the DW out performs at all fuel pressures vs the Aeromotive.
just my .02
Thanks
DC
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 12-17-2010   #11
mlomker
*Resting In Peace*
mlomker's Avatar
Absolutely. Every time I see fuel tests done (like the one a few months back by DSport), it is always the parallel Bosch 044 setup that blows everything else away. These pumps aren't quite as powerful as the 044 but close enough...certainly over 1k whp.
Old 12-17-2010   #12
I thought the Jay racing pump outflowed a 044?
Either way, I'm just gonna do a DW and deal locally with MAP if there is any issues which there shouldn't be, I met the DW guys and they seem pretty cool as well.
Old 02-08-2011   #13
Soooooo....it's nearing decision time and I'm looking at one of these three pumps. The flow data seems pretty similar on all of these, I'll likely be running 26-30psi on my X.
all around 300 at 60psi
and 275 at 70psi
base is ~40 and I'll run 26-30psi so in that 65-70psi fuel pressure range, right?
going up to 80psi though, the aeromotive kinda dies off and falls to 225, while the DW holds 250-255.
MAP has tested the DW300 with great results...has anyone else run any of these yet, or have any links to any more tests/stories?
Old 02-08-2011   #14
Hrm, no real data to back it up but wonder what the truth to this is (in reference to the aeromotive):
Originally Posted by davidbuschur View Post
For reference............this pump flows less than a modded Walbro, which use to be available only if you told us you were running E85 with our double pumper. It has been standard for the last few months. Just adding this so someone doesn't order it to replace a modded Walbro as they will end up with less flow.
http://forums.evolutionm.net/vendor-...fuel-pump.html
Old 02-08-2011   #15
and 275 at 70psi
Here is a rough overlay that was posted in that thread you posted comparing the DW and the Aeromotive
Would be nice if someone would make a chart for a modded walbro as well. Maybe if enough people bother Buschur he will test one. lol
Old 02-08-2011   #16
None of the pictures of these new pumps show the top of the pump real well, but seeing as how they are in the same casing, would it be safe to assume they could also have the pressure relief mod done to them?
Old 02-08-2011   #17
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Do these eliminate the use of a boost-a-pump or would that still be required for the 634hp? someone metioned earlier?
Old 02-08-2011   #18
Since I'm posting....
Guy at RS said he swapped a wally255 for the jay racing 340 and it made nearly no difference...this was not on the dyno when the swap occurred, but who knows. He also said it is nearly silent, which is kinda cool. End conclusion was that the pump wasn't getting enough voltage/amperage and needed to be rewired....might as well do a BAP at that point? IDK...
http://forums.evolutionm.net/alterna...fuel-pump.html
Also another guy with the jay racing pump, 1g dsm, said to make sure its rewired...
http://www.dsmtuners.com/forums/dyno...#post152424157
Searching around
Old 02-08-2011   #19
Not sure, but others have asked that too.
Not eliminate but perhaps put off when you'd need one. eg a stock 255 runs out of juice at 420whp @ db, but one of these could possibly support closer to 500whp. Put a BAP on one of these for extra crazy awesomeness I guess!
Old 02-08-2011   #20
FWIW, I think 311Evo made ~490-500 @ DB with the modded Walbro before the BAP
