Old 09-27-2011   #1
90AWDTSi
Drives: 90 Talon TSi
Grounding wire locations?
Hi im having an issue with an intermitent short to the mfi relay. the car will start and may run or will start and begin to have the rpms go from idle to zero and back and forth until the car dies altogether. i pulled the relay out and cleaned the contacts for the pins and the contacts themselves. im wondering if it could be a loose grounding wire? any ideas?
90AWDTSi is offline   Reply With Quote
Old 09-27-2011   #2
90AWDTSi
Re: Grounding wire locations?
sorry mpi relay
Old 09-27-2011   #3
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Idle air control, massive boost leak, maf not plugged in? If the MPI is not clicking on and off and the fuel pump is running I wouldn't look there.
Converted to LS
Old 09-27-2011   #4
90AWDTSi
It clicks on and off while its doing it.
