Old 08-27-2014   #1
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Fuel injector problem
I am wondering if anyone has come across this issue before and may have a resolution to my problem. The vehicle is a 94 talon awd turbo, I have a set of Evo 560 injectors that i wanted to use with the build. Some how during installation the last injector tip came off as you can see in the pictures below. After talking with Mitsubishi you can not buy them separate from the injector itself. So before i go through with buying a new set of injectors or a single one from Mitsubishi i figured id ask in case someone could help. Any help is appreciated.
ID:	14696   Click image for larger version
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 09-03-2014   #2
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
Re: Fuel injector problem
I believe that is just the pintle cap (might be misspelled). I think it just helps with turning the fuel into a vapor as its coming out. I have heard you can run without them, but I would HIGHLY recommend not doing that. I replaced mine after getting them from napa, so they may have they for the evo's that ran them.
Good luck man!
mitsukid124 is offline   Reply With Quote
Old 09-12-2014   #3
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
I'll look into that, thanks
-Matt
'06 Acura TL
