Old 09-03-2005   #10
Re: Vibrations after clutch install possible?
You need to pull the front cover off to do this. When you pull off the oil pump gear cover plate. the dots on the two gears need to line up if you'r using a balance shaft. if you do the elimination, it doesn't matter. You need to take the cover off to take out the balance shafts anyways.
