Old 09-15-2005   #2
Re: PS, A/C, Cruise
PS pretty easy unless it has a manual rack conversion. AC you need to run all the lines again, make sure none of them leak, put the condensor back in, hook up all connections. Get a conversion kit and hook up the compessor and belts and then make sure the system doesnt leak... and that would be a bitch of a job.
Cruise is easy, just a cable/box.
PS and Cruise are pretty easy, AC would be a bitch to find all the lines and connections and make them work. I would say its not worth it... especially if your going to add a FMIC which will make your car run hotter and not let you use the ac anyway...
