Old 09-21-2005   #18
rk4g63
Burp!
Send a message via Yahoo to rk4g63
Re: bad vibration in entire frame
yes, seems to get higher as I go faster. vibration at 70 is significantly more than at 50. Also, vibration seems to be more in the dash, center console and A-pillar - kind of the situation when you're in a high gear and coast down to a low speed - then forget and try to accelerate in that same high gear.
Also, seems to be rpm sensitive - 90% sure of that.
Starts more at about 50 maybe, but its also there at at lower speeds - I think thats when I'm accelerating hard - corresponds to higher rpms too.
Haven't checked pushing in the clutch at higher speeds - will try that tomorrow.
rk4g63 is offline   Reply With Quote
