Go Back   MitsuStyle > The Homefront! > Everything Racing
Old 10-02-2005   #37
Re: Nopi Nationals Sept 24-25 Moroso
Well I just pulled the CAS and the injectors thinking I could see if the #2 injector was firing or not, and Ya that's just about the stupidest things I've done, Basically it's what I get when I try to rush something and not think it through.
Basically as soon as I turned the CAS - the #4 cylinder injector shot out the bottom of the fuel rail dumping all the fuel that was in the rail onto the engine/floor. (at least I'm doing this when the car hasn't been driven all day)
So I think ok I'll hold the #4 injector in place and try again. And Sure enough the #3 injector comes flying out and all the fuel sprayed all over me and the engine. I'm surprised just how much fuel the Fuel Pump shoots into the fuel rail. It seemed as if it was almost full... Needless to say I stopped after that and put it all back together.
Anyrate - I have no idea if the CAS is bad or not the injectors sounded like they were firing before I pulled them out of place but I maybe I'm hearing thing, but it kind of sounded like the #2 was firing all the time? which is why I pulled the fuel rail to see if I could check the injector. I'm tired maybe I'll pull the CAS tomarrow and just listen to the injectors firing again. When I have more energy.
