Old 10-02-2005   #5
CDeutsch
CDeutsch's Avatar
Re: Priming the oil pump and break in ?'s
Make sure you disconnect the clutch switch so you can crank it without pushing in the clutch (in neutral obviously). You don't need to risk any wear on the thrust bearing before it has adequate oil.
Otherwise use a drill or air ratchet to spin the oil pump (with the timing belt off) like EclipseGST said.
06 Evo IX RS
99 Miata
