Old 10-13-2005   #23
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: Worried about my car...
Now if you and a brand new or rebuilt transmission, Than I would do a shift kit of some kind, run some Ford F type ATF and see if some improved clutch packs are available. But even changing the fluid on an older neglected automatic could kill the thing, (and Im sure you have Heard this by now) over time varnish and dirt build up by the shift valves, than when you change the fluid with new ATF you have all new detergents that clean the build up off then the valve so thay cant control the fluid, hence poor shifting if at all. But you have a problem starting so what the hell, try something.
Take her to the limit!
