Old 10-16-2005   #11
Re: Wheel spin developed recently in all gears except 5th
Originally Posted by Jakey
Correct me if I'm wrong JET but aren't there (2) 13mm bolts which hold the valve on? The rubber cap can be popped off my a small screwdriver.
That was the 90's, the later ones you just take the rubber cap off, push in the retaining pin and use a 2.5mm allen wrench to unscrew the valve. You need to make sure the tranny is in reverse and the clutch is pushed in. I put a 2x4 between the clutch pedal and the seat to hold the clutch down.
JET is offline
