Old 10-16-2005   #5
94talonawd
94talonawd's Avatar
Re: am i getting false vacuum reading?
sorry. Well it is for a 1g TSi AWD. When I first bought the car, the timing on the crank pulley was set advanced like around 20 degrees. When i took it home i set the base timing back to 5 degrees. I dont know if any of the teeth might have skipped. I was guessing that might be the problem. I was also going to replace the Intake manifold Gasket because i thought that it was leaking from there, but it looked pretty hard to take off so i had decided to ask you guys to see if there was any other problems i should also look into. I am pretty sure it isnt the intake manifold leaking, im pretty sure my timing has skipped some tooth. What would be the easiest way to check if my timing skipped a teeth?
SOLD
94 Talon AWD
Big 16G
SAFC-II
99 Civic D16 - EVO3 16G - Hondata S300 - Xenocron 4bar@21PSI - RC750cc's - Eagles/Vitara - Compcams
12.3@114, 1.81 60ft
-On it's way to 11's....
