Old 10-20-2005   #3
quick2.4
Re: Boost leak
Originally Posted by untouchable
I was curious if someone knew if there was an easy way to test for boost leak or does it have to be brought in?
you can make a boost leak tester for under 10.00
a coupler an a pcv fitting with an air line fitting in the end of it an hook it up to the turbo intake with 20-30 psi an plug it in an listen an you will ! find what your looking for
quick2.4 is offline   Reply With Quote
