Old 10-21-2005   #8
Re: Blown turbo cause of bad motor? WTF Now?
I'll follow up with super4x4, is there any shaft play? If there's no shaft play then something probably went through the turbine. If there is shaft play, then it's still possible the bearing failed, let loose, and the turbine slopped around the inside of the turbine housing (although it'd have to be pretty excessive shaft play for that to happen).
