Old 10-26-2005   #2
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
Re: I can't boost lower than 14-15 PSI and I think my O2 sensor is out
I think its your manual boost controller. Is that when you noticed the difference in psi, is when you installed the boost controller? You could change our you o2 sensor, but the readings is not affecting performance, just gas mileage, and CEL on a 2g.
If you cant change you boost right away, turn your base timing down, that should help out with any knock, and maybe lower injector duties.
2004 Dodge SRT4. Bone Stock
2006 Toyota Sienna. Swagger Wagon
SOLD 1992 Plymouth Laser AWD. 13.4 @ 102 Stock tune and turbo.
turbo2086 is offline   Reply With Quote
