Old 10-26-2005   #11
Re: Starting problem
I had that same problem when my caps on the ECU were leaking, but you have a new ECU it seems... also behind the radio it was clicking also.
You can get rid of all emmisions and that clicking FPR solenoid under the hood. You might want to look at your FPR itself, maybe its draining all the gas back to your tank and there isnt enough pressure to get the car going again?
Try running just the fuel pump for a few second with the logger, then fire it up and see if it takes? Could be a bad FPR?
