Old 11-10-2005   #16
Steeltwo
CompUSA Whore
Drives: 07 Civic Si, 06 IS 350 and I own a dsm
Send a message via ICQ to Steeltwo
Re: Towing with a DSM
Originally Posted by M/// Guy
I understand that totally but when your towing something there is not constant load on the car unless your going up a mountain to get somewhere... If you towing on the highway, you wont be using alot of turbo unless your going pretty fast or if you load is super heavy...
Also what about the heat made by turbodiesels?
that is why you have a boost controller, turn it up and down as you go.
but what might happen, is if the load is too heavy for the non boosted engine to maintain speed, even on a slight grade hill, it'll hit up boost. Of course it would do that without the load, just not too the extent.
The point he was trying to make was that, using the boost controller, i'c and cooler. That he could counter act the extra heat.
and that is a good question about the diesels, i'm not smart enough to ask him about those.
But as diesels are so different, i'm sure I wouldn't have been able to understand the answer had I asked.
91 tsi awd
07 Civic Si
06 IS 350
Steeltwo is offline   Reply With Quote
