Old 11-21-2005   #4
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: First gear is jacked.. need some help
Originally Posted by Speedfreak
When you did your clutch, you also installed a new fork and pivit ball. If the problem is internal, then the popping out of gear isn't a synchro issue, its a gear issue.
How do you figure? It could be a number of things... Bent shift fork, bent shift rail, bent/twisted synchro, bent imput shaft, or a broken gear. I'd put money on the synchro fucking up (since its brass and soft as hell) before the gear does on a pretty much stock GSX. Either that or a bent shift fork/rail would be my next guess if its internal. Make sure nothing is interfearing with your shifter linkages first then start to look for other things internal.
Originally Posted by shoutbox
