Old 12-31-2005   #4
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
Re: Fuel Trims maxing out.
Oh hey guys going to give ya an update on my fuel trims... I tested all the sensors, including the o2, everything came out A okay. I put a new fuel filter and PCV valve, just cause It hasnt been done since I owned the car...
Took the battery off while doing the fuel filter, so the ECU reseted. Once I started it up, the o2 cycled at idle, and fuel trims were all at 100%, like it should be. After about 5 days of daily driven, and some WOT pulls, my fuel trim low, and fuel trim high went back up to 139.8%. My fuel trim med is at at 122.8%
O2's used to cycle at idle, til today, which now reads .00v at idle. But if i just lightly tap the gas the o2s will read for a few seconds. So I know it must run rich at idle, so the EGTS are not high enough to get readings...
I guess I dont have a full understanding on fuel trims, and how I can keep them at 100%. In the mean time every few days I reset the ECU. I must say though my mpg has increased since doing all these resets, like 20mpg city, much better then what it used to be... Any feedback, or suggestions is appreciated about fuel trims and what not. Thanks My car is nearly stock, and does not have any fuel managment, fuel, or exhaust mods.
turbo2086 is offline   Reply With Quote
