Old 01-10-2006   #3
DSMkel
Send a message via AIM to DSMkel Send a message via MSN to DSMkel
Re: Bad ECU?
Does your buddies ECU work with no ill effects in your car? Usually when EPROMs go bad they just go and then nothing will work. They don't just start to fail and steadily get worse. I would suspect something else in the ECU to be bad like the caps or a trace somewhere might be broken.
My buddy's ECU works just fine in my car without any problems......why? My ECU causes my car to not startup right away, missfire until it warms up or goes past 4000rpms, and has little power.
I was actually thinkin about replacing the caps to see if that's the problem, because I don't think the caps have ever been replaced, but could that actually be the problem?
-Kel-
Type-Arrrrgh KILLA
"If it's never broke you're not driving it hard enough"
DSMkel is offline   Reply With Quote
