Old 01-26-2006   #28
Re: Noise when moving... transfer case?
One thing would be to make sure that the bolts that hold the cases together is tight. That will loosen up the bearing tolerances. Eventually the tranny may lock up if the bearing seizes, which will obviously be an issue. The longer it runs like that the worse it will get and it may do damage to other parts of the tranny.
