Old 01-26-2006   #1
Re: DKS Cams
Not sure if that statement is true. Think about why they are called "re-grinds". The reason for the shims is because the base circle of the cam is ground to a smaller diameter, to increase the lift of the cam in relation to the follower. If you make the base circle smaller, it makes the lobe bigger. The shims take up the difference.
That makes sense and would explain the shims. Hopefully they are getting them re-heat treated properly.
Old 01-26-2006   #2
riderevolution
riderevolution's Avatar
Re: DKS Cams
I would not spend the money on those cams! Pay a little more and go fp's or hks!
M@ :cool:
riderevolution is offline   Reply With Quote
Old 01-26-2006   #3
Re: DKS Cams
Agreed.
