Closed Thread
Old 02-08-2006   #1
Re: How did this hole get here??
it actually turns into a deisel and the computer adds or subtracts fuel depending on load, it does nothing to the throttle. maybe.
FattyBoomBatty is offline
Old 02-08-2006   #2
Wizard
Actually the only thing it controls is the throttle. Hence the box that is attached to the throttle cables known as the cruise unit. The only way I could see cruise causing engine problems is by pushing in the clutch and the engine not releasing the cruise hold. This is not the cruise control's fault necc. There is a switch on your clutch pedal that disengages the cruise. Also, if your motor can't handle a second of rev-limit or high rpms....it was probably on it's way out anyways.
Wiz
Wizard is offline
Old 02-08-2006   #3
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Wiz
Holy cow this guy is wayyyyy smart!
Way to be a newb to the board.
-Colin
cudvig is offline
Closed Thread
