Old 02-22-2006   #7
Re: Balance shaft eliminator on daily driver?
The front inner bearing is a biscuit to get out and a new one in, but don't skimp on this. You want that passage blocked for maximum oil pressure. Hint, you can actually drill, tap and plug that hole and leave the bearing in, there's an access bolt/stud in the block for each bearing.
