Old 02-25-2006   #1
TurboDomestics
TurboDomestics's Avatar
A million and one DSM problems.
My car has been acting really weird lately. I just walked a mile back home from where my DSM broke down.
Heres a list of all the problems with it, that I can think of right now:
-When driving it wont boost at all.
-When I do get it to boost, (hardly ever), it'll max out my 20 psi boost guage, an it wont go anywhere, all it does is overheat.
-The EGTs are incredibly high, I was cruising around in 2nd gear at 3000 rpm, at 0 psi, and the EGTs were up to about 1550*. This was about 2 mins before I pulled over and poped the hood. The manifold, turbo and O2 housing were all glowing red.
-Its also burning alot of oil, I can smell it but I cant figure out where its coming from, and I can see grey smoke come out of the exhaust sometimes. One time it I checked it and there was no oil on the dipstick. Not a drop. So I walked to autozone and bought some oil and filled it up.
-Whenever I try to start the car when its warm, all it does is just crank, it wont even sputter at all. And then the battery dies after about a minute of on and off cranking. It starts fine when its cold though.
-It only pulls about 5 to 10 vacuum at idle, and I can barely get it to create more than 15 when cruising.
-I has crazy exhaust leaks out of the cracked 1g manifold, I just replaced that with a semi ported 2g one.
-Its not throwing any CELs.
The stuff I have recently replaced:
-Fuel filter
-Spark plugs
-Accel wires
-K&N air filter
-Every single fluid in the car.
-Valve cover gasket
-Oil pan gasket.
-I put a new battery in, but the positive post is bent and I think its leaking battery acid. Im taking it back to Napa tomorrow.
Im guessing that there is more than one thing wrong with the car, I checked for boost leaks a few days ago, and fixed a few of them, but I did it at a gas station so I couldnt find them all.
Any ideas???
thanks soooo much
-Charlie
On a positive note, I am getting much more exercise from all the walking home, I have been doing.
4G63 0, Charlie 3
Old 02-25-2006   #2
thomyd
Drives: 1ga
Re: A million and one DSM problems.
have you done a compression test?
thomyd is offline   Reply With Quote
Old 02-25-2006   #3
TurboDomestics
No, i havent. But when Mike at QPR put it in my car, he said it had 142 across the board. That was 3000 miles, 1 car and about 6-7 months of sitting ago. Do you think much has changed since then?
Ill try to check tomorrow.
4G63 0, Charlie 3
Old 02-25-2006   #4
Junk turbo?
Old 02-25-2006   #5
Timing is way off. Belt probably jumped a tooth or two.
Old 02-25-2006   #6
absolutely, and exhaust leaks might cause your knock sensor to go off and retard timing even more, that happened to my quest, at least.
Old 02-25-2006   #7
Either a cooked turbo or jumped timing.
Old 02-25-2006   #8
TurboDomestics
ill check the timing, I think its the turbo though.
4G63 0, Charlie 3
Old 02-25-2006   #9
TurboDomestics
Ok, lets add one more symptom.
-I cant free rev past 2500 rpms.
-There is a very loud knocking sound coming from around the head.
Timing issue??
4G63 0, Charlie 3
Old 02-25-2006   #10
have you replaced the caps in your ecu?
Old 02-25-2006   #11
TurboDomestics
Nope, not yet, i was going to do the when I had DSMLink installed.
4G63 0, Charlie 3
Old 02-25-2006   #12
Probably a bent valve due to a skipped belt. The exhaust valves are now probably suck partially open. If your turbo died, you could have melted a valve (if the turbine wheel stopped spinning competely) as well. The "noise" is probably a cam follower rattling around in your head.
Stop driving the car immediatly and pull it apart.
Old 02-25-2006   #13
TurboDomestics
To check if the belt skipped, I can just take off the t-belt cover, and check to see if the arrows line up on the cam gears, right?
4G63 0, Charlie 3
Old 02-25-2006   #14
tim
tim's Avatar
What are your mods?
Old 02-25-2006   #15
TurboDomestics
-Big 16g ported and clipped
-550cc injectors
-255lph pump rewired
-Aeromotive AFPR
-2g MAF
-K&N
-Metal intake pipe
-Accel wires
-EGT and Boost gauge
-Ported 2g manifold
-2.5" turbo back exhaust
-TurboXS MBC
-Battery relocated to the back
-EGR blocked off
-No AC
-No CC
-No PS
-SouthBend Rally Clutch
Heres a pic I just snapped of the cam gears:
http://img.photobucket.com/albums/v2...e/Camgears.jpg
I probably need to check the bottom part of the t-belt though, right?
4G63 0, Charlie 3
Old 02-26-2006   #16
Yes. Line up the mark on the crank pulley and then check the cam gears.
Old 02-25-2006   #17
TurboDomestics
Pics of the head in between cylinders 2 and 3:
http://img.photobucket.com/albums/v2...nlude/Ohno.jpg
http://img.photobucket.com/albums/v2...nlude/ohno.jpg
Theres what I found when I pulled the Valve cover off, thats all that seemed out of the ordinary. Should I just go ahead and pull the head off??
Also I checked the turbo for play, and it moved about a milimeter from side to side, and I couldnt get it to move front to back. It didnt spin very freely but it did spin.
4G63 0, Charlie 3
Old 02-25-2006   #18
i'm not familiar with 2.0 heads, what am I seeing in those two pics inside the head? sorry for extra clutter here.
Old 02-25-2006   #19
TurboDomestics
Im not quite sure, but I think its an oil line and there was a bit of it that was shaved off. Thats all that appeared to be out of the ordinary.
4G63 0, Charlie 3
Old 02-25-2006   #20
ya well.....bad caps can allow a lot of gheyness to occur. Lightning gsx can tell if your caps leak, and if that is the case, fix it for a VERY reasonable price.
