Old 03-13-2006   #2
x-pride
x-pride's Avatar
Re: Radio Memory Resets
Sounds like your constant power wire is not working. Pull the radio out and check it with a meter to see if you have constant power. Sorry I don't know the color of the wire off the top my head but you should have only 2 12v wire. One will come on and off with your ignition and the other one is always on. If you are are not getting any power go and check your fuses (fuse panel). Is your dome light and horn working properly?
