Old 03-19-2006   #2
Re: Fuel Injector Clinic Fuel Injectors
More information would be nice. What are your supporting mods? What fuel managment you going to use? Fuel pump? FPR? If you are using a stand alone you can get bigger ones just incase you upgrade in the future.
But you start to limit how big you can go when you are using just a piggy back. If you went with big injectors then you might have to get a EPROM ECU and get a custom chip burned for it to compensate for the larger injectors. I can't remember how big of injectors you can get while just using a SAFC but I would guess its not very big.
So anyway you need more information on your goals, your post is way to vague to give you an educated opinion.
