Old 04-26-2006   #5
Re: NEED HELP ASAP!!!!! Crank Pin.
Im sure the Mitsubishi engineers put it there for a reason... I can't see how you'd die, or the world would end, if you installed it without the pin. I swear there is a machined ring the fhywheel sits on, and the there isn't much clearance with the bolt holes. If you can get me the dimensions of the dowel pin, I can either make you one or take one from school.
